跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Nexus 5 后盖更换
你所需要的
  1. Nexus 5 后盖更换, 后盖: 步骤 1 中的图像 1,3 Nexus 5 后盖更换, 后盖: 步骤 1 中的图像 2,3 Nexus 5 后盖更换, 后盖: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    购买
    • 用塑料撬棒来解开后盖顶部与侧边的卡扣。
    • 底部由海绵胶带固定于机身。完成前述步骤后,可使用三角撬片来最终取下后盖。
    • 因 SIM 卡插槽处的塑料非常薄,容易在拆解时断裂,请避免在 SIM 卡插槽附近撬开后盖。
    Wireless QI and NFC.
    Once I have put everything together with the new battery in place, I have as last replaced the plastic back cover, snapping all the clips back around the edges of the phone. Alas, I was quick to realise the QI Wireless charging has ceased to work.
    I almost blamed the battery, or worse, me.
    QUICK TIP: there is actually another clip in the middle of the plastic back cover - just press with your thumb just above the 'S' in NEXUS emblem and, voila! Snaps back in.
    Wireless charge and NFC - works, once again.
    cwioro - 回复
    you just saved me like 30 bucks. thank you so much.
    Robert Nolan -
    + 1, had the same issue and pressing just near the S fixed it! Thanks a lot!
    nicco82 -
    Just a me too, I had to press above the S and it was quite a snap
    Erik Karlin -
    There seems to be two contacts that snap into place. One is in line with the led pretty much in the middle of the phone and the second one in line with the camera lens on the opposite side to the lens. The middle one for me snapped pretty lightly, but the side one required a bit more pressure. After that the nfc started working again. Thanks for posting this!
    Dennis Millner -
    Is it hard to remove the battery door? Worried I might damage it.
    Ash - 回复
    When I openend the back cover I damaged two clips. One about 2.5cm (1 inch) below the volume controls and one on the other side about same height. The cover fits good without those two but on one side there is a small gap where the clip broke. But I have a hard cover protector on my phone so it's not that bad.
    simonlwheeler - 回复
    The case around the sim slot is pretty thin and easy to break, best to avoid using the pry tool at this point.
    Aled Morris - 回复
    Excellent tip, should be included in the main guide.
    fprades - 回复
    Hey Author, i need to ur expert advice...i replaced my nexus 5's back cover. since the new one did not have the vibrators battery i had to take it from the old one and connect it to the new one...on removing i noticed that it was stuck to the cover by a glue
    Question: what glue to use to hold the battery to the cover?
    suwaid akbar - 回复
    Any adhesive will do. I used a hot glue gun. You shouldn't need expert advice to figure that out. Use your head.
    tjt263 -
    The case around the volume control is also pretty thin.... I broke mine prying so avoid the pry there too.
    Also my back had glue at the bottom and I haven't seen mentioned
    kornerson - 回复
结论
要组装你的手机,请按逆序操作以下步骤。
43等其他人完成本指南。
由衷感谢以下译者:
en zh
80%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Gaetan
于12/26/12注册
9,574 声望
创作了18篇指南
5条评论
Where do you find backs for the Nexus 5? Thanks!
Mark Brown - 回复
You can find them on Ebay
christian colon - 回复
can you tell me if removing the cover of the nexus 5 GPS stops working well?
daniele neri - 回复
Back cover LG spare part numbers are:
Black: ACQ86691011
White: ACQ86691012
Red: ACQ86691013
Google them. Done.
nexus555 - 回复
Thank you very much.
Jesse Wind -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 36
总计 72,233
