跳转到主内容
Nextbook Premium 7SE Battery Replacement
你所需要的
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 1,3 Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 2,3 Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 3,3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 1,3 Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 2,3 Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 3,3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. 如何焊接和拆焊
    • Use caution when operating the soldering iron.
结论
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
另外一个人完成了本指南。
Walker Karstens
于10/30/16注册
364 声望
创作了3篇指南
团队
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 710
