跳转到主内容
Newport HT70 Pump Assembly Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. Newport HT70 Pump Assembly Replacement, Pump Assembly: 步骤 1 中的图像 1,1
    • Position the base assembly so that you may access it.
    • Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
  2. Newport HT70 Pump Assembly Replacement: 步骤 2 中的图像 1,1
    • The base plate will then come apart from the rest of the device with the pump assembly attached to it, as depicted in the following photo.
    • Inspect pump assembly for any damage or looseness.
  3. Newport HT70 Pump Assembly Replacement: 步骤 3 中的图像 1,1
    • If damage is found, replace the pump assembly by removing each tube individually and replacing as needed.
    • You may not need to replace the entire assembly if parts of it are still intact.
结论
Merek McGill
于04/07/20注册
520 声望
创作了5篇指南
团队
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 的会员
CPSU-PATON-S20S7G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 222
