跳转到主内容
NeuTab N9 Motherboard Replacement
你所需要的
  1. NeuTab N9 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the soldering gun to separate all soldered wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N9 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Carefully pull the ribbons out.
  4. NeuTab N9 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the three 1 mm screws from the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 214
