跳转到主内容
NeuTab Air7 Speaker Replacement
你所需要的
  1. NeuTab Air7 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 NeuTab Air7 Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 NeuTab Air7 Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Speaker Replacement, Speaker: 步骤 2 中的图像 1,2 NeuTab Air7 Speaker Replacement, Speaker: 步骤 2 中的图像 2,2
    • The following instructions require soldiering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • De-solder the red and black wire ends that connect the speaker to the motherboard.
  3. NeuTab Air7 Speaker Replacement: 步骤 3 中的图像 1,3 NeuTab Air7 Speaker Replacement: 步骤 3 中的图像 2,3 NeuTab Air7 Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the two 0.8 mm screws holding the cover of the speaker in place.
    • Remove the cover and the speaker.
结论
Jason Soares
于10/29/23注册
532 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 100
