跳转到主内容
Netgear WGR614v9 Capacitor Replacement
你所需要的
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: 步骤 2 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement: 步骤 2 中的图像 2,2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: 步骤 3 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement: 步骤 3 中的图像 2,2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: 步骤 4 中的图像 1,1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: 步骤 6 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement: 步骤 6 中的图像 2,2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: 步骤 7 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement, Capacitor: 步骤 7 中的图像 2,2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: 步骤 8 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement: 步骤 8 中的图像 2,2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: 步骤 9 中的图像 1,2 Netgear WGR614v9 Capacitor Replacement: 步骤 9 中的图像 2,2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: 步骤 10 中的图像 1,3 Netgear WGR614v9 Capacitor Replacement: 步骤 10 中的图像 2,3 Netgear WGR614v9 Capacitor Replacement: 步骤 10 中的图像 3,3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
结论
另外一个人完成了本指南。
Kyle Moore
于10/03/11注册
95 声望
撰写一个指南
团队
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G24
4 名成员
创作了11篇指南
一条评论
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,201
