跳转到主内容
Nest x Yale Lock Speaker Replacement
你所需要的
  1. Nest x Yale Lock Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Nest x Yale Lock Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Nest x Yale Lock Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Get the lock device and turn it around.
    • Take out the black cover by removing the screws as shown in picture #1 and pull it out gently just so.
    • All 3 screws are 0.25 inches high and are phillip screws.
    • Doing so gains access to the motherboard as shown in picture #3.
  2. Nest x Yale Lock Speaker Replacement: 步骤 2 中的图像 1,2 Nest x Yale Lock Speaker Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • On the white connector in picture #1, push down using a pointed tip object and then remove the connection using tweezers.
    • For the wider connection in picture #2, lift up the black switch and remove the connection using tweezers.
  3. Nest x Yale Lock Speaker Replacement: 步骤 3 中的图像 1,2 Nest x Yale Lock Speaker Replacement: 步骤 3 中的图像 2,2
    • Take out the motherboard by unscrewing the screws holding it shown in picture #1.
    • The screws are phillips and are 0.25 inches.
    • After removing the screw on the motherboard, pry the motherboard out using a prying tool shown in picture #2.
  4. Nest x Yale Lock Speaker Replacement: 步骤 4 中的图像 1,1
    • The small black part on the down right side of the motherboard is the audio.
结论
Christopher Gonzalez
于09/26/22注册
313 声望
创作了3篇指南
团队
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 21
总计 273
