当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
Turn the display over.
Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
Grasp the tab with your fingers and pull directly away from the motherboard.
Locate the blue tab which says, "2. Pull".
Use tweezers to pull the battery up and away from the display.
Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
Locate the blue tab which says "3 unplug".
Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
Locate the auto-away sensor.
Remove the four 3mm screws with a #0 Phillips screwdriver.
Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
Lift the auto-away sensor from motherboard using tweezers.
Peel the copper foil gently from the EMI shield.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于09/23/14注册
264 声望
创作了2篇指南
徽章: 11
+ 8更多徽章
USFT-BLACKWELL-F14S11G5
5 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 12
总计 2,054
