跳转到主内容
Nest Cam Wi-Fi Cable Replacement
你所需要的
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: 步骤 1 中的图像 1,1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: 步骤 2 中的图像 1,3 Nest Cam Wi-Fi Cable Replacement: 步骤 2 中的图像 2,3 Nest Cam Wi-Fi Cable Replacement: 步骤 2 中的图像 3,3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: 步骤 3 中的图像 1,3 Nest Cam Wi-Fi Cable Replacement: 步骤 3 中的图像 2,3 Nest Cam Wi-Fi Cable Replacement: 步骤 3 中的图像 3,3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: 步骤 4 中的图像 1,1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
结论
另外一个人完成了本指南。
Jade Weiss
于02/24/16注册
662 声望
创作了3篇指南
团队
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G1
7 名成员
创作了10篇指南
2条评论
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - 回复
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Kerrie Davies - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 32
总计 4,278
