简介
Without a steady Wi-Fi connection the Nest Cam is not functional. If your Nest Cam has bad reception or refuses to connect to the internet even after troubleshooting for connection problems, the Wi-Fi cable may need to be replaced.
你所需要的
Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
另外一个人完成了本指南。
2条评论
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
