跳转到主内容
Nest Cam IQ Camera Replacement
你所需要的
  1. Nest Cam IQ Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Camera Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Camera Replacement: 步骤 3 中的图像 1,1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Camera Replacement: 步骤 4 中的图像 1,2 Nest Cam IQ Camera Replacement: 步骤 4 中的图像 2,2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Camera Replacement: 步骤 5 中的图像 1,2 Nest Cam IQ Camera Replacement: 步骤 5 中的图像 2,2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Camera Replacement: 步骤 6 中的图像 1,3 Nest Cam IQ Camera Replacement: 步骤 6 中的图像 2,3 Nest Cam IQ Camera Replacement: 步骤 6 中的图像 3,3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Camera Replacement: 步骤 7 中的图像 1,1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Camera Replacement: 步骤 8 中的图像 1,2 Nest Cam IQ Camera Replacement: 步骤 8 中的图像 2,2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 143
