跳转到主内容
加入维修社区 - 创建账户
Nespresso Vertuo Next Power Button Replacement
你所需要的
  1. Nespresso Vertuo Next Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Nespresso Vertuo Next Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
    • Side an opening tool in between where the top cover meets the white head piece and apply force to push the cover off.
    • Remove the cover from the device.
  2. Nespresso Vertuo Next Power Button Replacement: 步骤 2 中的图像 1,2 Nespresso Vertuo Next Power Button Replacement: 步骤 2 中的图像 2,2
    • Use a T19 Torx screwdriver to remove the white top cover of the machine.
    • While pulling away the top cover, ensure that you don't pull out any wires or other parts.
  3. Nespresso Vertuo Next Power Button Replacement: 步骤 3 中的图像 1,2 Nespresso Vertuo Next Power Button Replacement: 步骤 3 中的图像 2,2
    • Pop out the power button by pressing your thumb on the button and pressing down.
  4. Nespresso Vertuo Next Power Button Replacement: 步骤 4 中的图像 1,2 Nespresso Vertuo Next Power Button Replacement: 步骤 4 中的图像 2,2
    • Use tweezers to unplug the wires from the power button.
    • Apply slight force and carefully pull the wire out as to not damage any pins.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Philip_S
于03/21/25注册
419 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-2, Botvin Spring 2025 UMass Dartmouth, Team 6-2, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S6G2
4 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 93
总计 706
