跳转到主内容
Nerf Dart Tag Furyfire Trigger Replacement
你所需要的
  1. Nerf Dart Tag Furyfire Trigger Replacement, Remove the screws: 步骤 1 中的图像 1,1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Panel: 步骤 2 中的图像 1,1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Trigger Replacement, Remove Black Cylinder: 步骤 3 中的图像 1,1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 步骤 4 中的图像 1,2 Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 步骤 4 中的图像 2,2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Trigger Replacement, Remove Pump Handle: 步骤 5 中的图像 1,1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Handle: 步骤 6 中的图像 1,1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 步骤 7 中的图像 1,2 Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 步骤 7 中的图像 2,2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Trigger Replacement, Disengage White Piece: 步骤 8 中的图像 1,1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 步骤 9 中的图像 1,2 Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 步骤 9 中的图像 2,2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
  10. Nerf Dart Tag Furyfire Trigger Replacement, Detach Black Piece from Trigger: 步骤 10 中的图像 1,1
    • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
  11. Nerf Dart Tag Furyfire Trigger Replacement, Remove Trigger: 步骤 11 中的图像 1,1
    • Once the black piece has been detached, the trigger can be lifted out of the device.
结论
To reassemble your device, follow these instructions in reverse order. Ensure that the spring located behind the trigger is attached to the limb on the backside of the trigger.
Bradley Penrow
于09/23/14注册
37 声望
创作了4篇指南
团队
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 749
