跳转到主内容
NETGEAR WGT624 v3 Capacitor Replacement
你所需要的
  1. NETGEAR WGT624 v3 Capacitor Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 2 中的图像 1,3 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 2 中的图像 2,3 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 3 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 3 中的图像 2,2
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 4 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 4 中的图像 2,2
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: 步骤 5 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 6 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 6 中的图像 2,2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Capacitor Replacement, Capacitor: 步骤 7 中的图像 1,1
    • Turn the motherboard so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 8 中的图像 1,1
    • Locate the four capacitors.
  9. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 9 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 9 中的图像 2,2
    • Turn the motherboard so that the bottom is facing upwards.
    • Locate the two soldered contacts for each capacitor.
  10. NETGEAR WGT624 v3 Capacitor Replacement: 步骤 10 中的图像 1,2 NETGEAR WGT624 v3 Capacitor Replacement: 步骤 10 中的图像 2,2
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
    • For proper soldering and de-soldering techniques, refer here.
    • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 3-31, Amido Winter 2013 Cal Poly, Team 3-31, Amido Winter 2013 的会员
CPSU-AMIDO-W13S3G31
3 名成员
创作了12篇指南
1指南评论
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
Vinod Kumar Polakonda - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,638
