跳转到主内容
Mr. Coffee TF6 Power Cord Replacement
你所需要的
  1. Mr. Coffee TF6 Power Cord Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Mr. Coffee TF6 Power Cord Replacement: 步骤 2 中的图像 1,2 Mr. Coffee TF6 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Mr. Coffee TF6 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Mr. Coffee TF6 Power Cord Replacement, Power Cord: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
  5. Mr. Coffee TF6 Power Cord Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • The power cord wiring is now completely accessible.
  6. Mr. Coffee TF6 Power Cord Replacement: 步骤 6 中的图像 1,2 Mr. Coffee TF6 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
  7. Mr. Coffee TF6 Power Cord Replacement: 步骤 7 中的图像 1,2 Mr. Coffee TF6 Power Cord Replacement: 步骤 7 中的图像 2,2
    • Using your fingers, pry the heatshrink off from the power cord leads.
  8. Mr. Coffee TF6 Power Cord Replacement: 步骤 8 中的图像 1,1
    • Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
  9. Mr. Coffee TF6 Power Cord Replacement: 步骤 9 中的图像 1,1
    • Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's ground lead to the bronze nylon wire.
    • Ensure the correct leads are being soldered together (power to power, ground to ground). Soldering the incorrect leads together will result in hazardous conditions for both the TF6 and the user when the unit is powered on.
    • Consult the replacement power cord's user manual, packaging, or manufacturer in order to verify the power and ground leads.
结论
Andrew
于01/24/14注册
116 声望
撰写一个指南
团队
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G18
4 名成员
创作了5篇指南
一条评论
Excellent! very helpful...
NP Designs 123 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 718
