本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacing the power cord on the TF6 requires several wiring tools and previous experience with soldering. For soldering tips and directions, consult the guide on how to solder and desolder connections.
你所需要的
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
即将完成!
结论
