跳转到主内容
Motorola syn1654A Speaker Module Replacement
你所需要的
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: 步骤 1 中的图像 1,2 Motorola syn1654A Speaker Module Replacement, Speaker Module: 步骤 1 中的图像 2,2
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: 步骤 2 中的图像 1,1
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: 步骤 3 中的图像 1,1
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: 步骤 4 中的图像 1,1
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: 如何焊接和拆焊
结论
Ben
于02/24/14注册
104 声望
撰写一个指南
团队
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G1
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 252
