跳转到主内容
Motorola syn1654A Microphone Replacement
你所需要的
  1. Motorola syn1654A Microphone Replacement, Microphone: 步骤 1 中的图像 1,2 Motorola syn1654A Microphone Replacement, Microphone: 步骤 1 中的图像 2,2
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. Motorola syn1654A Microphone Replacement: 步骤 2 中的图像 1,1
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Motorola syn1654A Microphone Replacement: 步骤 3 中的图像 1,3 Motorola syn1654A Microphone Replacement: 步骤 3 中的图像 2,3 Motorola syn1654A Microphone Replacement: 步骤 3 中的图像 3,3
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  4. Motorola syn1654A Microphone Replacement: 步骤 4 中的图像 1,1
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: 如何焊接和拆焊
结论
另外一个人完成了本指南。
John Ware
于02/24/14注册
325 声望
创作了2篇指南
团队
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 的会员
MTU-LAUER-S14S5G1
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 364
