本指南有最近更改,您可查看未经巡查的最新版本。
简介
Once the back cover, battery, motherboard, and keypad have been removed, the keypad cover will be accessible for removal.
你所需要的
Slide the cover release button towards the bottom of the phone
Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
The motherboard should now be completely disconnected from the phone.
Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
Once the keypad has been removed, the keypad cover can be easily peeled back from the front phone cover molding.
