跳转到主内容
Motorola Moto Z Play Speaker Replacement
你所需要的
  1. Motorola Moto Z Play Speaker Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Power your phone off before you begin.
    • If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
    • If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
  2. Motorola Moto Z Play Speaker Replacement: 步骤 2 中的图像 1,1
    • Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto Z Play Speaker Replacement: 步骤 3 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 3 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 3 中的图像 3,3
    • In the following steps, you will separate the display assembly from the Moto Z Play's chassis.
    • For reference, refer to the first image, showing the back of the display assembly (right) after it has been removed from the phone (left).
    • If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the display panel and damage it.
    • Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the display panel, which is good news if you plan to reuse it.
  4. Motorola Moto Z Play Speaker Replacement: 步骤 4 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 4 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 4 中的图像 3,3
    • Apply a suction cup to the display, near the middle of the left edge.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  5. Motorola Moto Z Play Speaker Replacement: 步骤 5 中的图像 1,1
    • Insert an opening pick (or playing card) into the gap you opened behind the display.
  6. Motorola Moto Z Play Speaker Replacement: 步骤 6 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 6 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 6 中的图像 3,3
    • Slide the tool all along the left edge of the phone to slice through the adhesive securing the display.
  7. Motorola Moto Z Play Speaker Replacement: 步骤 7 中的图像 1,1
    • Heat the front of the phone between the display and the lower edge to soften the adhesive underneath.
  8. Motorola Moto Z Play Speaker Replacement: 步骤 8 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 8 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 8 中的图像 3,3
    • Slice through the glue under the lower bezel, being careful not to damage the fingerprint sensor.
    • Slide or roll your tool past the lower edge of the fingerprint sensor and continue to the other side. Do not pry directly underneath the sensor.
    • If you plan to re-use the display, be careful not to slice or pry at the display panel. Refer to this image to help identify the glued areas while avoiding the display panel (highlighted in red).
  9. Motorola Moto Z Play Speaker Replacement: 步骤 9 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 9 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 9 中的图像 3,3
    • Continue separating the glue underneath the rest of the lower bezel.
  10. Motorola Moto Z Play Speaker Replacement: 步骤 10 中的图像 1,1
    • Heat the right edge of the phone to soften the adhesive securing the right edge of the display.
  11. Motorola Moto Z Play Speaker Replacement: 步骤 11 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 11 中的图像 2,2
    • Slide your tool along the right edge of the phone to separate the glue securing the display.
  12. Motorola Moto Z Play Speaker Replacement: 步骤 12 中的图像 1,1
    • Heat the front of the phone between the display and the top edge.
  13. Motorola Moto Z Play Speaker Replacement: 步骤 13 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 13 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 13 中的图像 3,3
    • Insert your tool at the top right corner of the phone, and begin to slide it underneath the top bezel to separate the glue.
    • As before, if you want to re-use the display, don't insert the tool far enough to touch the display panel.
    • When your tool just passes the left edge of the earpiece speaker, stop.
    • Slide or roll your tool over the top of the flash module for the selfie camera to avoid damaging it.
  14. Motorola Moto Z Play Speaker Replacement: 步骤 14 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 14 中的图像 2,2
    • If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
    • Lift the display from the left edge and swing it open, away from the phone.
  15. Motorola Moto Z Play Speaker Replacement: 步骤 15 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 15 中的图像 2,2
    • While holding the display open, use the point of a spudger to pry up the locking tab on the fingerprint sensor cable's ZIF connector.
  16. Motorola Moto Z Play Speaker Replacement: 步骤 16 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 16 中的图像 2,2
    • At the opposite end of the phone, use your spudger to flip open the locking tab on the display cable connector.
  17. Motorola Moto Z Play Speaker Replacement: 步骤 17 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 17 中的图像 2,2
    • Gently pull the fingerprint sensor cable to slide it out of its socket, disconnecting it from the motherboard.
  18. Motorola Moto Z Play Speaker Replacement: 步骤 18 中的图像 1,2 Motorola Moto Z Play Speaker Replacement: 步骤 18 中的图像 2,2
    • Gently pull the display cable to slide it out of its socket on the motherboard.
  19. Motorola Moto Z Play Speaker Replacement: 步骤 19 中的图像 1,1
    • Remove the display assembly.
  20. Motorola Moto Z Play Speaker Replacement, Speaker: 步骤 20 中的图像 1,2 Motorola Moto Z Play Speaker Replacement, Speaker: 步骤 20 中的图像 2,2
    • Remove the SIM card by firmly pressing the 0.8 SIM eject tool into the SIM card removal hole on the top left edge of the phone until the SIM slot pops out of the phone.
    • Remove the SIM card completely from the device
  21. Motorola Moto Z Play Speaker Replacement: 步骤 21 中的图像 1,3 Motorola Moto Z Play Speaker Replacement: 步骤 21 中的图像 2,3 Motorola Moto Z Play Speaker Replacement: 步骤 21 中的图像 3,3
    • Remove the five 3 mm T3 screws from the black camera cover at the top of the phone.
    • Pry the camera cover up with your fingers to pop the camera cover clips loose.
  22. Motorola Moto Z Play Speaker Replacement: 步骤 22 中的图像 1,1
    • Pry the speaker unit from the camera cover with the smallest plastic opening tool.
结论
Reminder: Use 3M VHB Double Sided Tape to stick the screen back onto the phone.
Kaitlyn Fisher
于10/01/17注册
2,012 声望
创作了3篇指南
团队
Cal Poly, Team S15-G4, Livingston Fall 2017 Cal Poly, Team S15-G4, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S15G4
4 名成员
创作了16篇指南
4条评论
I wanted to replace it because it just wasn’t as loud as it used to be but when I put the new speaker in I noticed that it made the sound all distorted at more than about half volume so I took it out and put the old one back in and now it’s doing the same thing too!! Help!
Matthew - 回复
I found out that that happens when the glass isn’t sealed tightly to the frame. In my case I messed up the adhesive on one of the corners when reinstalling the screen and it didn’t seal tightly. The glass being properly held down is what stops the distortion. When playing back without the screen sealed it will distort and this is normal.
Matthew -
thanks exactly the same thing happened to me, i replaced the Moto Z Play 1635-03 speaker and I got distortion just like you did, however I haven’t sealed it yet as the special glue hasn’t arrived yet (B-7000 glue) and pressing on the front screen which is loose certainly reduces the sounds distortion so I will have to get it right and adjust it accordingly when the glue arrives, making sure it sets at the optimal position.
Interesting my Moto Z Play 1635 is the dual sim version (can take two) and it was one of the first generation models of this phone, the strange this is that it has a thin copper coil wound at the BACK of the sealed speaker component with two lose ends (like a speaker coil); this is not something I see in all the Youtube speaker tear down videos Moto Z Play. I would the two loose copper coil ends and tucked them into the center of the coil; which sits there like a coil for the speaker component. Dunno if I am doing this right.
Dave Dogge - 回复
I recently replaced the battery and the screen and now the speaker isn't working. I get audible alerts but no sound on a call or from any apps. I do get sound on Bluetooth connected devices. What happened and what do I need to do to correct this?
Bruce Pauley - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 3,999
