简介
Use this guide to replace the motherboard in your Motorola Moto X.
你所需要的
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
Use the flat end of a spudger to disconnect the NFC antenna cable connector.
Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
Use the flat end of a spudger to free the interconnect cable connector.
Remove the interconnect cable from the motherboard.
8等其他人完成本指南。
3条评论
Where i can find motherboard scheme?
Where is the Bluetooth/WiFi filter?
Mine doesn't work, I need to replace it. I'm from India.
What are the other alternatives for the filter? I mean, other filters that can be used (Replacement for the original one, ofcourse).
I've been using my Moto X (1st Gen) as an Mp3 player/Camera/Video Player. I don't want to continue using it this way. This smartphone is one of the best mankind has ever manufactured. Any help is much appreciated.
Thank you.
Email: amleakhilesh@gmail.com
Where can I buy this motherboard?
Also where can I buy another back facing camera?
