当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector.
Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
Use the adhesive pull-tab to lift the battery from its recess.
The battery is secured to the motherboard with mild adhesive. Peel slowly, and be careful not to bend or puncture the battery.
Remove the battery from the phone.
When reassembling your phone secure the battery with double-sided tape or pre-cut adhesive strips.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
