本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you step-by-step how to replace your worn out keyboard buttons.
你所需要的
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Simply lift the keyboard buttons with your hands pulling from one side to the other.
即将完成!
结论
