跳转到主内容
Motorola Moto G7 Play Front Facing Camera Replacement
你所需要的
  1. Motorola Moto G7 Play Front Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G7 Play Front Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Front Facing Camera Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 6 中的图像 1,2 Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 7 中的图像 1,2 Motorola Moto G7 Play Front Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
  8. Motorola Moto G7 Play Front Facing Camera Replacement, Front Facing Camera: 步骤 8 中的图像 1,1
    • Separate the front facing camera from the motherboard while removing the adhesive .
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 391
