跳转到主内容
Motorola Moto G7 Play Camera Replacement
你所需要的
  1. Motorola Moto G7 Play Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G7 Play Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Camera Replacement: 步骤 2 中的图像 1,1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Camera Replacement: 步骤 3 中的图像 1,2 Motorola Moto G7 Play Camera Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Camera Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Lift the motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Camera Replacement: 步骤 6 中的图像 1,2 Motorola Moto G7 Play Camera Replacement: 步骤 6 中的图像 2,2
    • Once the motherboard cover is removed, use the iFixit opening tool to disconnect the ribbon cable connecting the camera to the motherboard.
    • The camera can now be removed and is ready to be replaced.
结论
另外一个人完成了本指南。
Monserath Casillas
于02/10/20注册
1,161 声望
创作了5篇指南
团队
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 的会员
CPSU-REGAN-W20S7G4
5 名成员
创作了12篇指南
一条评论
My camera stopped working after water damage. Replacing the camera itself didn’t fix it. What could the problem be?
abb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 966
