简介
This guide will show you how to properly remove the motherboard and replace it with a new one.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
Gently twist or pry to open a small gap between the back cover and the body of the phone.
While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
Gently pry straight up to disconnect the battery.
Peel off any tape securing the battery wires, and then push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
Pry up with your spudger to flip open the locking flap on the headphone jack's ZIF connector.
在这个步骤中使用的工具:Tweezers$4.99
Grasping the motherboard by its edges, left the bottom end up at an angle, while keeping the top edge close to the phone.
Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame. The camera can remain attached to the motherboard.
Using your tweezers, grasp the headphone jack flex cable and carefully pull it out of its socket as you remove the motherboard.
Remove the motherboard.
8等其他人完成本指南。
