跳转到主内容
Motorola MC5590 Internal Antenna Replacement
你所需要的
  1. Motorola MC5590 Internal Antenna Replacement, Battery: 步骤 1 中的图像 1,1
    • Push in the battery release button.
  2. Motorola MC5590 Internal Antenna Replacement: 步骤 2 中的图像 1,1
    • Pull out battery.
  3. Motorola MC5590 Internal Antenna Replacement, Keyboard: 步骤 3 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Internal Antenna Replacement: 步骤 4 中的图像 1,3 Motorola MC5590 Internal Antenna Replacement: 步骤 4 中的图像 2,3 Motorola MC5590 Internal Antenna Replacement: 步骤 4 中的图像 3,3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Internal Antenna Replacement: 步骤 5 中的图像 1,1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Internal Antenna Replacement: 步骤 6 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 6 中的图像 2,2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Internal Antenna Replacement: 步骤 7 中的图像 1,1
    • Remove the keyboard cover.
  8. Motorola MC5590 Internal Antenna Replacement: 步骤 8 中的图像 1,3 Motorola MC5590 Internal Antenna Replacement: 步骤 8 中的图像 2,3 Motorola MC5590 Internal Antenna Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Internal Antenna Replacement: 步骤 9 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Internal Antenna Replacement, Speaker: 步骤 10 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement, Speaker: 步骤 10 中的图像 2,2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Internal Antenna Replacement: 步骤 11 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 11 中的图像 2,2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Internal Antenna Replacement: 步骤 12 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 12 中的图像 2,2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Internal Antenna Replacement: 步骤 13 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 13 中的图像 2,2
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Internal Antenna Replacement, LCD Screen: 步骤 14 中的图像 1,3 Motorola MC5590 Internal Antenna Replacement, LCD Screen: 步骤 14 中的图像 2,3 Motorola MC5590 Internal Antenna Replacement, LCD Screen: 步骤 14 中的图像 3,3
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Internal Antenna Replacement: 步骤 15 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 15 中的图像 2,2
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Internal Antenna Replacement: 步骤 16 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 16 中的图像 2,2
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Internal Antenna Replacement: 步骤 17 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement: 步骤 17 中的图像 2,2
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Internal Antenna Replacement, Internal Antenna: 步骤 18 中的图像 1,2 Motorola MC5590 Internal Antenna Replacement, Internal Antenna: 步骤 18 中的图像 2,2
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
结论
Tyler Jean
于02/22/18注册
555 声望
创作了5篇指南
团队
USF Tampa, Team S1-G6, Cagle Spring 2018 USF Tampa, Team S1-G6, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 288
