跳转到主内容
Motorola Droid Turbo Dual LED Flash Board Replacement
你所需要的
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    This di not work; I had to use a blow dryer.
    Caroline Downie - 回复
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: 步骤 2 中的图像 1,2 Motorola Droid Turbo Dual LED Flash Board Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
    Ryan Helinski - 回复
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 步骤 3 中的图像 1,2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: 步骤 3 中的图像 2,2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
    No parts? Really?
    Rongwey - 回复
    What I meant to say was great job! Also I have a question about the adhesive pads holding the flash on. Shouldn't they be replaced as well? My flash wasn't working so I took the back off and cleaned the contacts and put it back together. It worked fine for a couple of days and went back to only blinking. The pads seem to be letting the flash part move with the chop motion to activate the flashlight,
    Rongwey - 回复
结论
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
90,038 声望
创作了89篇指南
一条评论
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 971
