跳转到主内容
加入维修社区 - 创建账户
Motorola Droid RAZR Back Cover Replacement
你所需要的
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Droid RAZR Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: 步骤 2 中的图像 1,3 Motorola Droid RAZR Back Cover Replacement: 步骤 2 中的图像 2,3 Motorola Droid RAZR Back Cover Replacement: 步骤 2 中的图像 3,3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: 步骤 3 中的图像 1,3 Motorola Droid RAZR Back Cover Replacement: 步骤 3 中的图像 2,3 Motorola Droid RAZR Back Cover Replacement: 步骤 3 中的图像 3,3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
结论
7等其他人完成本指南。
David Hodson
于04/13/10注册
154,988 声望
创作了127篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 14,459
