当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Position Motorola C290 so that the back of the phone is facing up.
Apply pressure to the back cover while simultaneously sliding it downwards.
Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
Note: This will reveal a screw. Five screws should now be visible.
Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
Remove logic board cover and set aside.
Insert the Spudger into the slot on the top of the logic board.
Gently pry to loosen the top of the logic board.
Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
Grab the top of the logic board and pull at an angle to remove.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
