本指南有最近更改,您可查看未经巡查的最新版本。
简介
This process involves first removing the battery, outer case, and motherboard. After, the keypad can be easily removed.
你所需要的
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
Peel the keypad from the front case.
The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
