当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Remove the battery by pushing the bottom end towards the top, then lifting up.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
Remove the motherboard by lifting it up and out.
Peel the keypad from the front case.
The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
取消:我没有完成这个指南。
与4其他贡献者
于04/15/12注册
26 声望
撰写一个指南
徽章: 4
+1个徽章
CPSU-AMIDO-S12S6G21
4 名成员
创作了18篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 572
