跳转到主内容
Moto G4 Front-facing Camera Replacement
你所需要的
  1. Moto G4 Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,3 Moto G4 Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,3 Moto G4 Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Front-facing Camera Replacement: 步骤 2 中的图像 1,2 Moto G4 Front-facing Camera Replacement: 步骤 2 中的图像 2,2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Front-facing Camera Replacement: 步骤 3 中的图像 1,3 Moto G4 Front-facing Camera Replacement: 步骤 3 中的图像 2,3 Moto G4 Front-facing Camera Replacement: 步骤 3 中的图像 3,3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Front-facing Camera Replacement: 步骤 4 中的图像 1,2 Moto G4 Front-facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Front-facing Camera Replacement, Midframe: 步骤 5 中的图像 1,3 Moto G4 Front-facing Camera Replacement, Midframe: 步骤 5 中的图像 2,3 Moto G4 Front-facing Camera Replacement, Midframe: 步骤 5 中的图像 3,3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Front-facing Camera Replacement: 步骤 6 中的图像 1,2 Moto G4 Front-facing Camera Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Front-facing Camera Replacement: 步骤 7 中的图像 1,1
    • Remove the rubber cover.
  8. Moto G4 Front-facing Camera Replacement: 步骤 8 中的图像 1,2 Moto G4 Front-facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Front-facing Camera Replacement: 步骤 9 中的图像 1,1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Front-facing Camera Replacement: 步骤 10 中的图像 1,1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Front-facing Camera Replacement: 步骤 11 中的图像 1,1
    • Remove the midframe.
  12. Moto G4 Front-facing Camera Replacement, Battery Disconnection: 步骤 12 中的图像 1,2 Moto G4 Front-facing Camera Replacement, Battery Disconnection: 步骤 12 中的图像 2,2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  13. Moto G4 Front-facing Camera Replacement, Front-facing Camera: 步骤 13 中的图像 1,3 Moto G4 Front-facing Camera Replacement, Front-facing Camera: 步骤 13 中的图像 2,3 Moto G4 Front-facing Camera Replacement, Front-facing Camera: 步骤 13 中的图像 3,3
    • It's not necessary to remove the battery in order to replace the front-facing camera; you can safely ignore the fact that the battery is missing in these images.
    • Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame.
    • Peel back and remove any tape covering the front-facing camera's flex cable connector.
    • Pry up with your spudger or other ESD-safe tool to flip open the locking flap on the front-facing camera's ZIF connector.
    • Gently pull the camera's flex cable free from the ZIF socket.
  14. Moto G4 Front-facing Camera Replacement: 步骤 14 中的图像 1,1
    • Remove the front camera.
结论
Kieran Basheer
于02/12/18注册
122 声望
撰写一个指南
团队
USF Tampa, Team S15-G3, Boczar Spring 2018 USF Tampa, Team S15-G3, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S15G3
4 名成员
创作了12篇指南
一条评论
Merci pour ce tutoriel très simple qui m'a permis (à 76 ans) de facilement remplacer la camera avant qui ne fonctionnait plus suite à une chute.... Prix de la camera trouvée sur Ebay 6€
Jean-Charles
facebook - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 789
