跳转到主内容
Moto C Plus Screen Assembly Replacement
你所需要的
  1. Moto C Plus Screen Assembly Replacement, Back Cover: 步骤 1 中的图像 1,3 Moto C Plus Screen Assembly Replacement, Back Cover: 步骤 1 中的图像 2,3 Moto C Plus Screen Assembly Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Plus Screen Assembly Replacement: 步骤 2 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 2 中的图像 2,2
    • Lift the phone out of the back cover.
  3. Moto C Plus Screen Assembly Replacement, Battery: 步骤 3 中的图像 1,3 Moto C Plus Screen Assembly Replacement, Battery: 步骤 3 中的图像 2,3 Moto C Plus Screen Assembly Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
  4. Moto C Plus Screen Assembly Replacement, Daughterboard Cover: 步骤 4 中的图像 1,1
    • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
  5. Moto C Plus Screen Assembly Replacement: 步骤 5 中的图像 1,3 Moto C Plus Screen Assembly Replacement: 步骤 5 中的图像 2,3 Moto C Plus Screen Assembly Replacement: 步骤 5 中的图像 3,3
    • Apply a spudger to the right side of the daughterboard cover.
    • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
    • Remove the daughterboard cover.
  6. Moto C Plus Screen Assembly Replacement, Motherboard Cover: 步骤 6 中的图像 1,1
    • Remove the five 3.1 mm long Phillips #00 screws.
  7. Moto C Plus Screen Assembly Replacement: 步骤 7 中的图像 1,3 Moto C Plus Screen Assembly Replacement: 步骤 7 中的图像 2,3 Moto C Plus Screen Assembly Replacement: 步骤 7 中的图像 3,3
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
  8. Moto C Plus Screen Assembly Replacement: 步骤 8 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
  9. Moto C Plus Screen Assembly Replacement, Motherboard Assembly: 步骤 9 中的图像 1,1
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
  10. Moto C Plus Screen Assembly Replacement: 步骤 10 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 10 中的图像 2,2
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
  11. Moto C Plus Screen Assembly Replacement: 步骤 11 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  12. Moto C Plus Screen Assembly Replacement: 步骤 12 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 12 中的图像 2,2
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
  13. Moto C Plus Screen Assembly Replacement: 步骤 13 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 13 中的图像 2,2
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
  14. Moto C Plus Screen Assembly Replacement: 步骤 14 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 14 中的图像 2,2
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
  15. Moto C Plus Screen Assembly Replacement: 步骤 15 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 15 中的图像 2,2
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
  16. Moto C Plus Screen Assembly Replacement: 步骤 16 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 16 中的图像 2,2
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
  17. Moto C Plus Screen Assembly Replacement: 步骤 17 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 17 中的图像 2,2
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
  18. Moto C Plus Screen Assembly Replacement: 步骤 18 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 18 中的图像 2,2
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
  19. Moto C Plus Screen Assembly Replacement: 步骤 19 中的图像 1,1
    • Remove the motherboard.
  20. Moto C Plus Screen Assembly Replacement, Daughterboard: 步骤 20 中的图像 1,2 Moto C Plus Screen Assembly Replacement, Daughterboard: 步骤 20 中的图像 2,2
    • Disconnect the antenna cable and fold it out of the way.
  21. Moto C Plus Screen Assembly Replacement: 步骤 21 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 21 中的图像 2,2
    • Use the tip of a spudger to open the brown flap of the ZIF connector that holds the interconnect cable in its place.
  22. Moto C Plus Screen Assembly Replacement: 步骤 22 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 22 中的图像 2,2
    在这个步骤中使用的工具:
  23. Moto C Plus Screen Assembly Replacement: 步骤 23 中的图像 1,1
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
  24. Moto C Plus Screen Assembly Replacement: 步骤 24 中的图像 1,3 Moto C Plus Screen Assembly Replacement: 步骤 24 中的图像 2,3 Moto C Plus Screen Assembly Replacement: 步骤 24 中的图像 3,3
    • Apply an opening pick to the bottom edge of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Take care to cut the adhesive underneath the vibration motor.
    • Slide the opening pick from right to left to cut all the adhesive.
  25. Moto C Plus Screen Assembly Replacement: 步骤 25 中的图像 1,1
    • Remove the daughterboard including the soldered-on vibration motor.
  26. Moto C Plus Screen Assembly Replacement, Earpiece Speaker: 步骤 26 中的图像 1,1
    • Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
  27. Moto C Plus Screen Assembly Replacement: 步骤 27 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 27 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully grab and remove the earpiece speaker.
  28. Moto C Plus Screen Assembly Replacement, Screen Assembly: 步骤 28 中的图像 1,2 Moto C Plus Screen Assembly Replacement, Screen Assembly: 步骤 28 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the rubber headphone jack gasket in the corner of the display assembly.
  29. Moto C Plus Screen Assembly Replacement: 步骤 29 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 29 中的图像 2,2
    • Use a pair of tweezers to remove the rubber charging port gasket.
  30. Moto C Plus Screen Assembly Replacement: 步骤 30 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 30 中的图像 2,2
    • Use a pair of tweezers to grab and remove the microphone rubber gasket at the bottom right end of your phone.
  31. Moto C Plus Screen Assembly Replacement: 步骤 31 中的图像 1,1
    • Use an iOpener to loosen the adhesive tape that sits on top of the interconnect and display flex cable. Apply the iOpener on the tape for at least two minutes.
  32. Moto C Plus Screen Assembly Replacement: 步骤 32 中的图像 1,3 Moto C Plus Screen Assembly Replacement: 步骤 32 中的图像 2,3 Moto C Plus Screen Assembly Replacement: 步骤 32 中的图像 3,3
    • Use a pair of tweezers to gently peel the adhesive tape off the flex cables and fold it out of the way.
  33. Moto C Plus Screen Assembly Replacement: 步骤 33 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 33 中的图像 2,2
    • Use a pair of tweezers to gently peel the product sticker off the interconnect cable.
    • In case you can't remove the sticker or it starts to rip apart you can re-apply an iOpener to loosen the adhesive.
  34. Moto C Plus Screen Assembly Replacement: 步骤 34 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 34 中的图像 2,2
    • Use a pair of tweezers to grab and carefully peel up the interconnect flex cable.
    • Remove the interconnect flex cable.
  35. Moto C Plus Screen Assembly Replacement: 步骤 35 中的图像 1,2 Moto C Plus Screen Assembly Replacement: 步骤 35 中的图像 2,2
    • Use a pair of tweezers to remove the antenna cable.
  36. Moto C Plus Screen Assembly Replacement: 步骤 36 中的图像 1,1
    • Check your replacement part for any other components that need to be transferred before reassembly.
结论
3等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
247,305 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 2,493
