跳转到主内容
Moto C Motherboard Assembly Replacement
你所需要的
  1. Moto C Motherboard Assembly Replacement, Back Cover: 步骤 1 中的图像 1,3 Moto C Motherboard Assembly Replacement, Back Cover: 步骤 1 中的图像 2,3 Moto C Motherboard Assembly Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
    • Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
  2. Moto C Motherboard Assembly Replacement: 步骤 2 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 2 中的图像 2,2
    • Lift the phone out of the back cover.
  3. Moto C Motherboard Assembly Replacement, Battery: 步骤 3 中的图像 1,3 Moto C Motherboard Assembly Replacement, Battery: 步骤 3 中的图像 2,3 Moto C Motherboard Assembly Replacement, Battery: 步骤 3 中的图像 3,3
    • Use a finger or spudger to lever the battery out of its recess and remove it.
  4. Moto C Motherboard Assembly Replacement, Motherboard Cover: 步骤 4 中的图像 1,1
    • Remove the six 3.5 mm long Torx T5 screws.
  5. Moto C Motherboard Assembly Replacement: 步骤 5 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 5 中的图像 2,2
    • Insert an opening pick between the cover and the motherboard near the SIM 2 slot where the power buttons are located.
    • Slide and twist the opening pick to pry open the plastic clips securing the cover.
  6. Moto C Motherboard Assembly Replacement: 步骤 6 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 6 中的图像 2,2
    • Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot.
    • Twist the opening pick to pry open the plastic clips securing the cover.
  7. Moto C Motherboard Assembly Replacement: 步骤 7 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove the motherboard cover.
  8. Moto C Motherboard Assembly Replacement, Motherboard Assembly: 步骤 8 中的图像 1,1
    • Remove the three 2.5 mm long T5 Torx screws.
  9. Moto C Motherboard Assembly Replacement: 步骤 9 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 9 中的图像 2,2
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard.
  10. Moto C Motherboard Assembly Replacement: 步骤 10 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
  11. Moto C Motherboard Assembly Replacement: 步骤 11 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 11 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the display flex cable located at the bottom of the motherboard.
  12. Moto C Motherboard Assembly Replacement: 步骤 12 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 12 中的图像 2,2
    • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located at the top of the motherboard next to the rear camera.
  13. Moto C Motherboard Assembly Replacement: 步骤 13 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 13 中的图像 2,2
    • Use a pair of tweezers to pull the digitizer flex cable out of the ZIF connector.
  14. Moto C Motherboard Assembly Replacement: 步骤 14 中的图像 1,1
    • Prepare an iOpener and apply it to the upper half of the display for at least two minutes to loosen the adhesive beneath the vibration motor and the rear facing camera.
  15. Moto C Motherboard Assembly Replacement: 步骤 15 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 15 中的图像 2,2
    • Don't try to remove the motherboard all the way yet. The antenna cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
  16. Moto C Motherboard Assembly Replacement: 步骤 16 中的图像 1,3 Moto C Motherboard Assembly Replacement: 步骤 16 中的图像 2,3 Moto C Motherboard Assembly Replacement: 步骤 16 中的图像 3,3
    • Fold the motherboard over the battery cavity to access the coaxial cable connectors.
  17. Moto C Motherboard Assembly Replacement: 步骤 17 中的图像 1,2 Moto C Motherboard Assembly Replacement: 步骤 17 中的图像 2,2
    • Use a pair of tweezers to pry up and disconnect the antenna cable from the back of the motherboard.
  18. Moto C Motherboard Assembly Replacement: 步骤 18 中的图像 1,1
    • Remove the motherboard.
结论
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
211,758 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,076篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 1,822
