跳转到主内容
加入维修社区 - 创建账户
Motherboard Replacement
你所需要的
  1. Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove masking tape from the battery.
  4. Motherboard Replacement: 步骤 4 中的图像 1,3 Motherboard Replacement: 步骤 4 中的图像 2,3 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: 步骤 5 中的图像 1,3 Motherboard Replacement: 步骤 5 中的图像 2,3 Motherboard Replacement: 步骤 5 中的图像 3,3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. 如何焊接和拆焊
    • Use caution when operating the soldering iron.
  6. Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: 步骤 8 中的图像 1,3 Motherboard Replacement: 步骤 8 中的图像 2,3 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
结论
另外一个人完成了本指南。
Connor Fisher
于11/04/16注册
212 声望
撰写一个指南
团队
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G1
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 476
