跳转到主内容
加入维修社区 - 创建账户
Motherboard Replacement
你所需要的
  1. Motherboard Replacement, Fellowes T7CM Casing and Trigger Replacement: 步骤 1 中的图像 1,1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    询问修复机器人
    添加评论
  2. Motherboard Replacement: 步骤 2 中的图像 1,1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    添加评论
  3. Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    询问修复机器人
    添加评论
  4. Motherboard Replacement: 步骤 4 中的图像 1,1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    询问修复机器人
    添加评论
  5. Motherboard Replacement, On,  Off, Reverse Switch: 步骤 5 中的图像 1,1
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
    询问修复机器人
    添加评论
  6. Motherboard Replacement: 步骤 6 中的图像 1,2 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
    询问修复机器人
    添加评论
  7. Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Desolder the wires from the motherboard. Learn more about soldering componentshere!
    询问修复机器人
    添加评论
  8. Motherboard Replacement: 步骤 8 中的图像 1,1
    • After all of the wires are removed, the motherboard can be lifted off and removed with ease.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
John Wisthoff
于10/12/16注册
487 声望
创作了3篇指南
团队
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G2
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 1,244
