跳转到主内容
加入维修社区 - 创建账户
Mortise Lock Replacement
你所需要的
  1. Mortise Lock Replacement, Unscrew the Door Handle: 步骤 1 中的图像 1,2 Mortise Lock Replacement, Unscrew the Door Handle: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Unscrew the set screw holding the door handle using a 3mm hex key.
    • Some security doors might not have a set screw and instead require you to remove the whole faceplate.
  2. Mortise Lock Replacement, Remove the Handles: 步骤 2 中的图像 1,2 Mortise Lock Replacement, Remove the Handles: 步骤 2 中的图像 2,2
    • Remove both handles by pulling them out of the lock.
    • Take care not to lose the little plastic rings. They act as a bearing, ensuring that turning the door handle feels easy and smooth.
    • Some special doors, such as fire doors or steel doors, will require you to remove the faceplate in order to remove the lock, as with these, it mounts through the lock body.
  3. Mortise Lock Replacement, Remove the Lock: 步骤 3 中的图像 1,1
    • Should you have a cylinder installed, you will have to take it out before you can remove the lock.
    • Remove the two screws securing the lock to the doorframe.
    • Pull the lock out towards you.
结论
Sebastian
于08/19/18注册
31,811 声望
创作了71篇指南
团队
German Translators German Translators 的会员
Community
45 名成员
创作了1,557篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 1,198
