跳转到主内容
Mitsubishi Hands Free Module Firmware Update (MMCS NR-242)
你所需要的
  1. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): 步骤 1 中的图像 1,2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): 步骤 1 中的图像 2,2
    • Enter the Service Menu by pressing and holding the SETTINGS and MAP-Buttons for 4 seconds.
  2. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (W-15 & W-17): 步骤 2 中的图像 1,1
    • Enter the Service Menu by pressing and holding the INFO/SET and SEEK-Buttons for 4 seconds.
  3. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: 步骤 3 中的图像 1,2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: 步骤 3 中的图像 2,2
    • Press on Hands Free Module.
    • While the Hands Free Module is in diagnosis mode, the sound input to the microphone unit is output directly through the speaker.
    • Check the Parts Number.
    • We'll need this later when downloading the Firmware file.
    • Check the Version Number.
    • If the Version Number is 19.00.000 or 50.00.000 you already have the last available Firmware installed and don't need to do anything.
  4. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: 步骤 4 中的图像 1,2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: 步骤 4 中的图像 2,2
  5. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Move the File: 步骤 5 中的图像 1,1
    • The flash drive needs to be formatted to FAT32 and should not be larger than 16GB. Additionally the MMCS can be a bit picky and might not accept all flash drives. If it can't read your flash drive, just try a different one.
    • Copy the update.package file to the root directory of the USB flash drive.
  6. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Insert the flash drive: 步骤 6 中的图像 1,1
    • Insert the USB flash drive into one of the USB ports in your car.
    • You can usually find a USB port inside the center console or below the head unit.
  7. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Initiate the Update: 步骤 7 中的图像 1,1
    • Re-enter the Hands Free Module-Section of the Service Menu.
    • Press on the S/W Update-button.
    • If there is no S/W Update-button it means that the head unit didn't detect a valid file on the flash drive. This either means that you already have a version newer than the firmware file installed (as is the case for me), an incompatible firmware file, or that the system can't read the flash drive.
  8. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Security PIN: 步骤 8 中的图像 1,1
    • Enter your Security PIN.
    • If you don't have one set you can just enter 1234.
    • If you have forgotten you Security PIN, you can forcibly remove it by pressing the Unlock-Button in the Hands Free Module-Section of the Service Menu.
  9. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: 步骤 9 中的图像 1,2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: 步骤 9 中的图像 2,2
    • Wait for the update to finish. This may take some time, don't worry if the progress bar stays at 0% for some time.
    • Do not remove the flash drive or turn off the car while the update is running!
    • If the update fails and the warning message states that you should make sure that the USB port is properly powered, you can just reboot the head unit and try again.
  10. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Finish: 步骤 10 中的图像 1,1
    • Press OK to finish the update.
结论
Drive safe!
2等其他人完成本指南。
Sebastian
于08/19/18注册
23,008 声望
创作了62篇指南
团队
German Translators German Translators 的会员
Community
28 名成员
创作了780篇指南
6条评论
gut erklärt.Aber eine frage habe ich bringt so ein update was ?????
Alex Kahle - 回复
Ja, auf der Wiki Seite steht sogar welche Bugs gefixt wurden.
Sebastian -
Danke für deine Antwort
Frage habe die Versionsnummer 50.00.000 ist die alt ?
und bleibt mein DAB+ radio und meine lenkrad steuerung nach den update.
Alex Kahle - 回复
Version 50 ist die neuste und letzte, du musst also kein Update machen.
Sebastian -
I had tried update firmware in my outlander 2016. Now my car doesn't even detect hands free module at all. I had removed battery power supply and tried again but hands free module doesn't show in service mode. Please support.. How can i make it work? It seems there ia firmware mismatch. How can i repair it? Is there software available to connect with this HFM? Please help.
ABD - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 50
过去 30 天: 207
总计 2,019
