本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you need to replace the circuit board on your Milwaukee M18 2606-20 cordless power drill (replaced the battery but still no power) see this guide on how to remove it. The circuit board is the brain of the drill and controls most components in the drill. Some reasons the circuit board may need replacement are the white light is not turning on or the drill is turning on and the battery has been replaced. See our How to Solder and Desolder Connections Guide for help with the final steps of the guide.
你所需要的
Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
一条评论
Replacement M18 Battery for Milwaukee Power Tool 2606-20
Type: Li-ion
Volt: 18V
Capacity: 5000mAh
Color: Black
Weight: 932g
Dimension: 141.15 x 78.00 x 73.95mm
Milwaukee 2606-20 Power Tool Batteries are made from the highest quality parts and are compatible with the Milwaukee cordless tools. And, this Milwaukee 2606-20 battery can be charged with original battery charger. Go to view more about this battery on https://www.drill-batteries.com/batteryp...
