跳转到主内容
Milwaukee Hex Impact Driver 2753-20 Trigger Replacement
你所需要的
  1. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: 步骤 1 中的图像 1,2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Battery: 步骤 1 中的图像 2,2
    • While pinching the red locking buttons, pull the battery away from the front of the drill until the battery is fully removed.
    • The battery is missing from this device so its removal is being mimed.
  2. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: 步骤 2 中的图像 1,1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  3. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 步骤 3 中的图像 1,2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  4. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: 步骤 4 中的图像 1,2 Milwaukee Hex Impact Driver 2753-20 Trigger Replacement, Trigger: 步骤 4 中的图像 2,2
    • Lift the trigger assembly from the device. It is connected to the circuit board by wires.
    • Carefully desolder the wires off of the trigger assembly using a soldering iron on medium heat.
    • Refer to this guide for proper desoldering technique.
  5. Milwaukee Hex Impact Driver 2753-20 Trigger Replacement: 步骤 5 中的图像 1,1
    • Remove the trigger assembly from the device.
    • Replace old trigger assembly with replacement part no. 14-20-0013.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 46
总计 4,527
