跳转到主内容
Milwaukee Hackzall 2625-20 Trigger Replacement
你所需要的
  1. Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: 步骤 1 中的图像 1,2 Milwaukee Hackzall 2625-20 Trigger Replacement, Trigger: 步骤 1 中的图像 2,2
    • Use a T9 Torx screwdriver to remove the one 7.0 mm screw.
    • Use a T10 Torx screwdriver to remove the one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight 16.0 mm screws.
    • Remove the casing to reveal the internal components.
  2. Milwaukee Hackzall 2625-20 Trigger Replacement: 步骤 2 中的图像 1,1
    • Use a soldering iron to desolder the connections on the back of the trigger assembly.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  3. Milwaukee Hackzall 2625-20 Trigger Replacement: 步骤 3 中的图像 1,2 Milwaukee Hackzall 2625-20 Trigger Replacement: 步骤 3 中的图像 2,2
    • Remove the rest of the trigger assembly from the case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 1,697
