跳转到主内容
Milwaukee Hackzall 2625-20 Terminal Block Replacement
你所需要的
  1. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: 步骤 1 中的图像 1,2 Milwaukee Hackzall 2625-20 Terminal Block Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Terminal Block Replacement, Terminal Block: 步骤 2 中的图像 1,1
    • Carefully remove the terminal block from the casing and note that there is a spring set into it.
  3. Milwaukee Hackzall 2625-20 Terminal Block Replacement: 步骤 3 中的图像 1,2 Milwaukee Hackzall 2625-20 Terminal Block Replacement: 步骤 3 中的图像 2,2
    • Use a soldering iron to melt any existing soldered attachments.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,437
