跳转到主内容
Milwaukee Hackzall 2625-20 Motor Replacement
你所需要的
  1. Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: 步骤 1 中的图像 1,2 Milwaukee Hackzall 2625-20 Motor Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the screws holding the shell of the device together. Each screw size varies; you will use a T9 Torx screwdriver for one size 7.0 mm.
    • Use a T10 Torx screwdriver to remove one 14.0 mm screw.
    • Use a T15 Torx screwdriver for the remaining eight screws that are 16.0 mm.
    • Remove the casing to reveal all of the internal components.
  2. Milwaukee Hackzall 2625-20 Motor Replacement, Electric Motor: 步骤 2 中的图像 1,1
    • Find the red and black wire running from the back of the motor to the trigger mechanism.
    • With a soldering iron remove the two solders on the trigger mechanism.
  3. Milwaukee Hackzall 2625-20 Motor Replacement: 步骤 3 中的图像 1,2 Milwaukee Hackzall 2625-20 Motor Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws connecting the motor to the gear box with a T15 torx screwdriver.
    • The motor is now free and can be removed from the tool.
结论
2条评论
Is there any chance to change only brushes in this motor?
Marcin Kędzior - 回复
That’s my exact question as well, nobody seems to cover this..
Anthony DeSanto - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 43
总计 2,319
