跳转到主内容
Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement
你所需要的
  1. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Orient your saw sideways so that the blade is facing downwards.
  2. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: 步骤 2 中的图像 1,3 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: 步骤 2 中的图像 2,3 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 6 mm screws using a Torx T4 screwdriver.
    • Remove the single 8 mm screw at the bottom that attaches the panels together using a Torx T6 screwdriver.
    • Slowly pull and remove the front panel of the saw that connects to the blade side with your hand, and separate it from the motor.
  3. Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Trigger: 步骤 3 中的图像 1,2 Milwaukee Circular Saw 263020 B57A 2008 Trigger Replacement, Trigger: 步骤 3 中的图像 2,2
    • Remove four 10 mm screws that attach the wires to the trigger using a Phillips #2 screwdriver.
    • Gently move the wires from the trigger (the wires should just come off).
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 13
过去 30 天: 35
总计 152
