跳转到主内容
Mid F900 Speaker Replacement
你所需要的
  1. Mid F900 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: 步骤 2 中的图像 1,2 Mid F900 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
结论
Jacques Pierre
于09/07/16注册
336 声望
创作了2篇指南
团队
USF Tampa, Team 6-6, Remmell Fall 2016 USF Tampa, Team 6-6, Remmell Fall 2016 的会员
USFT-REMMELL-F16S6G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 140
