跳转到主内容
Microsoft Surface Pro 5 Screen Adhesive Replacement
你所需要的
  1. Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 1,3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 2,3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: 步骤 1 中的图像 3,3
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: 步骤 2 中的图像 1,2 Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: 步骤 2 中的图像 2,2
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 5 Screen Adhesive Replacement, Install the display: 步骤 3 中的图像 1,1
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro 6 answers community for help.
2等其他人完成本指南。
Sam Omiotek
于02/25/19注册
67,876 声望
创作了288篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 92
总计 1,919
