跳转到主内容
Microsoft Surface Pro 11 SSD Replacement
你所需要的
  1. Microsoft Surface Pro 11 SSD Replacement, Before you begin: 步骤 1 中的图像 1,3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: 步骤 1 中的图像 2,3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: 步骤 1 中的图像 3,3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: 步骤 2 中的图像 1,3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: 步骤 2 中的图像 2,3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: 步骤 2 中的图像 3,3
    • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
  3. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: 步骤 3 中的图像 1,3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: 步骤 3 中的图像 2,3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: 步骤 3 中的图像 3,3
    • Use your finger to firmly press down on the SSD door indent until the door pops up.
    • Remove the SSD door.
  4. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: 步骤 4 中的图像 1,2 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: 步骤 4 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
  5. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: 步骤 5 中的图像 1,3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: 步骤 5 中的图像 2,3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: 步骤 5 中的图像 3,3
    • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
    • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
    • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
    • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
结论
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
3等其他人完成本指南。
Spencer Day
于09/14/22注册
154,757 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 143
过去 30 天: 722
总计 3,670
