跳转到主内容
Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement
你所需要的
  1. Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Flip your laptop over: 步骤 1 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Flip your laptop over: 步骤 1 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Flip your laptop over: 步骤 1 中的图像 3,3
    • Close your laptop and lay it down so the rubber feet are facing up.
  2. Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Remove the feet: 步骤 2 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Remove the feet: 步骤 2 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) Feet Replacement, Remove the feet: 步骤 2 中的图像 3,3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
结论
Spencer Day
于09/14/22注册
94,557 声望
创作了662篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,417篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 37
总计 235
