跳转到主内容
Microsoft Surface Laptop 3 15" Surface Connect Port Replacement
你所需要的
  1. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Prepare your device: 步骤 1 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Prepare your device: 步骤 1 中的图像 2,2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Flip the laptop over: 步骤 2 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Flip the laptop over: 步骤 2 中的图像 2,2
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Removal tip: 步骤 3 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Removal tip: 步骤 3 中的图像 2,2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the rear feet: 步骤 4 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the rear feet: 步骤 4 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the rear feet: 步骤 4 中的图像 3,3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the front feet: 步骤 5 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the front feet: 步骤 5 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the front feet: 步骤 5 中的图像 3,3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Reassembly tip: 步骤 6 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Reassembly tip: 步骤 6 中的图像 2,2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Reassembly tip: 步骤 7 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Reassembly tip: 步骤 7 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Reassembly tip: 步骤 7 中的图像 3,3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the upper case screws: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Open the display: 步骤 9 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Open the display: 步骤 9 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Open the display: 步骤 9 中的图像 3,3
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Lift up the upper case: 步骤 10 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Lift up the upper case: 步骤 10 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Lift up the upper case: 步骤 10 中的图像 3,3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the ribbon cable: 步骤 11 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the ribbon cable: 步骤 11 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the ribbon cable: 步骤 11 中的图像 3,3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the upper case: 步骤 12 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the upper case: 步骤 12 中的图像 2,2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the SSD screw: 步骤 13 中的图像 1,1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the SSD: 步骤 14 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the SSD: 步骤 14 中的图像 2,2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  15. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the port connector: 步骤 15 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the port connector: 步骤 15 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Disconnect the port connector: 步骤 15 中的图像 3,3
    • Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
    • Grip the Surface Connect port cable and pull it away from its connector to remove it.
  16. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the port cover: 步骤 16 中的图像 1,1
    • Use a T3 Torx driver to remove the four screws securing the Surface Connect port cover:
    • Two 2.0 mm screws
    • Two 2.1 mm screws
  17. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement: 步骤 17 中的图像 1,2 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement: 步骤 17 中的图像 2,2
    • Remove the Surface Connect port cover.
  18. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement, Remove the port: 步骤 18 中的图像 1,1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the Surface Connect port.
  19. Microsoft Surface Laptop 3 15" Surface Connect Port Replacement: 步骤 19 中的图像 1,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement: 步骤 19 中的图像 2,3 Microsoft Surface Laptop 3 15" Surface Connect Port Replacement: 步骤 19 中的图像 3,3
    • Pull the Surface Connect port away from the edge of the chassis to remove it.
结论
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
2等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
118,976 声望
创作了341篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,066篇指南
2条评论
QQ, Where do you get the replacement part?
Alex Ford - 回复
Second this; Did you find a reliable place to get the replacement port?
Max Beard -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 117
总计 4,416
